Excuse me for writing in english because i know only a few words in polish like ja perdole and kurva matka. I know these from polish Youtube videos LOL.
Let me introduce my BMW which i have built 2-3 years ago. It has competed in many drag races, won a few trophies and never let down.
Best results so far - 10.64s / 238kmh. But don't be confused its a 100% pure street car
Recently i have bought a Dynapack hub dyno and measured the power at the lowest turbo pressure (boost controll off).
It made 389WHP @ 0.87bar (DIN) at the wheels. I'm to busy now so can't afford working on my own car now.
Since i have swapped old 960cc injectors to 2400cc, engine mapping has to be verified and/or remapped.
I hope soon i will have more time so i will be able tune my E30 Turbo back to 2.4-2.5bar race boost. I will let you know the results !
Car:
BMW E30 320i Edition 1990.09
Engine:
M50B25 no Vanos, 10:1
Con rods, pistons, head gasket - stock
Utenos Termodinamika head studs (made in Lithuania)
Engine control:
VEMS v3.7
(Wideband lambda, Boost control, EGT)
Turbo system:
Holset HX52 67mm billet, T4 16cm
Twin scroll exhaust manifold
HKS 50mm style WG
Fuel system:
Bosch 2400cc/min @ 3.5bar injectors
2 x Bosch 044 fuel pumps
2 x Bosch (Audi) fuel filters
2,5 liter fuel swirl tank
10mm feed hose
E85
Ignition:
VAG FSI/TFSI ignition coils
Intake:
76mm stainless steel Intercooler piping
600x300x76mm IC
SFS Performance silicone hoses
100mm Green Filter air filter
Exhaust:
76mm stainless steel everything
Custom middle silencer (made in Lithuania)
Magnaflow rear silencer, 100mm Swedish style exhaust tip
V-Band clamps
Powersprint flex pipe
Transmission:
M3/328i ZF gear box
M30 single mass flywheel 240mm
Clutchnet red pressure plate
Stock clutch disc
188mm LSD differential 3.25:1
Suspension:
Koni E30 M3 adjustable shocks absorbers
H&R Race springs
H&R sway bars
Intrax camber plates, front *
Wiechers strut brace, front *
Powerflex rear axle bushings alround
Hard polyurethane differential bushing
E30 M3 front wishbone eccentric bushes (Lemforder)
All other stock suspension parts were replaced to brand new ones (Lemforder)
E36 328i steering rack
Brakes:
Stock for now. Brakes only for loosers ? :(
No ABS
Interior:
RECARO Profi SPG seat (E30 M3 DTM)
Sabelt 6 pt. light safety harness (E30 M3 DTM)
IRP/Wilwood hydraulic hand-brake *
M-Technic2 steering wheel
Exterior:
Hella black headlights
MHW black taillights
WA-Team light bonnet (made in Lithuania), 3M CF wrap
Alpina B6 3,5 wheels - 7jx16 205/50, 8jx16 225/45
BBS RS001 7jx15 wheels - M/T ET Drag 26/8.5-15 race slicks
* - not installed yet
